    • By Junaid Ahmed
    • By Ganesh R
      Hi LG Team,
      Regards,
      Ganesh R
    • By Nishant singh
      Hi Team
    • By Gabor Monzak
      The LG Gallery is a very nice application, I use it many times, but unfortunately there are few classical paintings. Unfortunately, uploaded user images are represented by a variety of transitions and animations, which greatly worsens the artwork.
      It would be good if:
      - The number of factory-downloadable images would increase to multiple
      - Simply display user UHD images without any crossover animation (get the effect on and off)
      - It would be possible to play back-up images in random order.
