  • 30
Unable to load user agreements
I have recently purchased an LG 43UH610T television.  I am located in Bali, Indonesia.  Everything seems to be working fine, but when I click on any of the options, such as LGTV, YouTube etc, it tells me I must first consent to the LG Smart TV user agreement.  However, I then get a message saying "Unable to load user agreements - a server error has occurred ......"
Can you help?
On 5/5/2017 at 9:54 PM, Fazakas Zsóki said:
I have recently bought a 43uh661v LG TV and have the same issue. The User Agreements are unable to load. The internet connection is working, I can access  all websites.  I tried to change the DNS to 8.8.8.8 (Google's public DNS) but it is still not working. Were you able to manage to solve the problem? If yes, how? Thank you!
Some users have gotten around the issue by hotspotting with their mobile phones.
Problem solved by doing the following:
1.connect to a mobile hotspot
2. Go to settings, general , account management
3. Register or sign in
4. Accept all agreements
5. Complete registration
6. disconnect mobile hotspot and connect to wifi
Problem solved!
No way, nor via hotspot, nor via dns change, nor reset to factory defaault.
43UH650V of 2016  … tech.assistence in Aosta ask 250€ to change motherboard cause it's a virus!
LG please give a solution asap
- modello: 43UH650V-ZB (s/n 605MAYY6N554)
- versione TV webOS: 3.3.4-4212
- archiviazione: 0.34/0.62
- SW File: 05.50.55
My solution was change the automatic location in to manual and to another country and it worked right away.
Problem solved!
Problem solved!
You need to go to settings -> General->About this TV.
Check for Updates -> Update TV.
When it finishes, restart the TV.
note: it is not finished updating when the screensaver comes on.
Go into settings again to check the update progress.
On 2/9/2018 at 11:46 AM, lance hokanson said:
I had the same problem. It turned out that the tv was auto detecting a different router in the house that required a password instead of the one it was directly connected to that did not require a password.
I just unplugged the other router. The tv then auto detected the correct one and the user agreement downloaded.
This worked for me. I disconnected the router my TV was connected to and switched to a different network (mobile hotspot). The user agreement then appeared and everything is working. This happened to me on my LGC2 42.
LG don't appear to have the user agreements working for all countries, which is ridiculous but there you go. In my case, it was South Africa. I had to manually switch the country to Saudi Arabia on the LG device in the location setting (which caused a reboot), then go to the LG website on my PC and register a username with the country as Saudi Arabia, then back to the LG device (now booted up again) and choose the agreement option in the menu, then use the newly created username to sign the agreement(s). I connected the LG device to my mobile hotspot for all of this, then switched it back to the usual wifi router afterwards.
    • By Hasan Ghasabi-Oskoei
      Can you help?
      LG Radio+ Brings LG Smart TV Users Free Listening to a Wide Range of
      Popular Podcasts and Live Stations, Also Accessible From LG’s Audio Devices
      SEOUL, Dec. 20, 2024 — LG Electronics (LG) has launched LG Radio+, the company’s ad-supported audio streaming service, now available on LG smart TVs running webOS 6.0 and above. This new service allows users to effortlessly access a diverse selection of podcasts and radio programs. For a streamlined user experience, LG Radio+ will work with the LG ThinQ app,1 providing users with a convenient way to access and enjoy their favorite audio content no matter where they are in the room.
      To offer a curated list of audio streaming content, LG has partnered with global radio and audio provider Radioline, giving users an all-in-one audio platform allowing effortless access to news, sports, music and more. Available in the U.S. and Korea, LG smart TV users can explore a range of live stations and podcasts, with options such as NPR, CNN Radio, Fox Radio or The Joe Rogan Experience in the U.S., or popular local stations and podcasts in Korea.
      The LG Radio+ app can be accessed from the Content Store or Apps or by using the voice search function of the LG Magic Remote, providing a fast and convenient way to discover new listening content.
      For quick and easy exploration, LG Radio+ has an intuitive interface with a comprehensive channel list, presenting popular audio channels on the On Air page, alongside a personalized selection of favorite channels. Users can navigate the On Air and Podcast pages to access their desired audio streaming content, while the Featured page provides a dynamic view of trending music, updated in real-time to highlight the most popular or season hits. This enables users to search, discover and enjoy their preferred audio content with ease out of a large library of over 14,500 channels in the U.S. and over 440 available in Korea.
      As part of LG’s commitment to enhancing user convenience and connectivity across the company’s life-enriching products, listeners will be able to access LG Radio+ through the LG ThinQ app,2 enabling enjoyable audio streaming on LG audio devices with minimal effort. What’s more, LG Radio+ will also be available to access through the My button on xboom speakers in 2025.
      LG continues to elevate the user experience with a broad range of content and an intuitive user interface, making it effortless to explore and enjoy audio entertainment. To learn more about how LG is enhancing the audio experience, visit
      1 Available at a later date in 2025.
      2 Accessible via xboom category
    • By keshav iyer
    • By alfie
    • By Muser
