Magic remote problem
By Venkata
Hello Team,
By PVD
By RJ Fischer
By hollean
Vaibhav
Hii
Having 43lh600t
When i connect my smartphone with my tv through screen sharing it start sharing but my magic remote cursor conver from red colour to "black and white " and stop working
