LG55UH6030 rebooting randomly
By wallyricks
By dinoc
Hi everyone,
Since the last OS SW update for webOS 23.2050 for my OLED LG TV 65C3 I have noticed a weird problem where the TV randomly shuts down by itself while watching TV, Netflix, YouTube … I couldn’t find a pattern when and how this happens it seems to behave like this randomly. I
t’s like.a SW crash behaviour memory leak or something (just an assumption).
I mention this is not the energy saving auto power off feature.
Have you guys encountered such issue?
By Rolivhuwa Muelelwa
I have been struggling with the Tidal App on my LG C1. You play music, but it random stops playing. Both on Wired connection and WiFi connect. I basically can't listen to any full song, without the audio randomly stopping.
By Riccardo
Hello to everyone,
I am new to the forum. I wanted to ask whether I am alone with this problem or it is common.
My set up: PC-DolbAtmos, LG-CX, SONOS ARC (eARC).
I've notice the audio connection between the PC and LG+ARC was unstable. Finally I noticed LG-CX sometimes forward (passthrough) the good Dolby Atmos signal and some other times it passes a signal which is WMA (not supported by the sonos device).
PC is set to always send "Atmos", when WMA is sent, simply changing "passthrough->PCM->Passthrough" in the LG audio menu solves the problem.
Why is know that LG-CX randomly passes the good signal at times and at other times doesn't ?
Would you have any tricks to help out ? maybe force audio to be transcoded by the TV (possible?) to be alway DD+ ?
Thanks a lot for any kind of help and suggestions.
By kurabasakuku
We have ProCentric 400 with V version, and 400+ Smart Hospitality TVs.
The following is the topology (attached).
We had issue lately: in random TVs have blank the channels with No Signal message. This occurs in some TVs, other TVs are just blank screen and there is no "No Signal" Message. After doing factory reset and reconfiguration then all is working normal. However this case then occurs to other TVs.
I was assuming this is network issues: switch configuration or else, but I am now very sure there is no configuration change.
Please advise.
TV No signal Issue.mp4
