Some questions about webos/magic remote from new user
By Trev
1. For well over a year the Antenna Channel Guide has been incomplete. Is there a way to manually update the guide?
The Prime app has suffered from two problems:
2. No subtitle option on movies, fixed by app uninstall/reinstall. Is there an easier fix?
3. 4K movies downgrade to SDR or SD momentarily, app uninstall/reinstall did NOT fix this?
TV software is upto date. Internet speed is good. Cache has been cleared by power disconnect/reconnect.
I have not tried Reset To Original settings, will that wipe out antenna channel & HDMI input name customizations?
Thanks.
By Hasan Ghasabi-Oskoei
Can you help?
By RJ Fischer
By The Old Man
Hey LG
Yes I am NOT happy
