LG has a Feedback and Suggestions Form
By Mohammad1403
Hello there,
How to remove pre-installed apps from webos 23 like Netflix and Amazon prime?
By Phil Seddon
SkyQ won't let me turn on 10 bit UHD even though it is supported by my LG OLED55C14 tv
By Stephen Davies
I've recently bought a 49" LG NANO866 TV and so far, am very pleased with it, especially when viewing UHD content, but I'd like to enhance the audio. The crescent stand on this model is both functional & stylish, but doesn't really lend itself to having a soundbar in front of it, even the LG SK1 with a width of 650mm isn't that well accommodated within the curve of the stand below the TV. Any suggestions?
Stephen.
By Joakim Lundström
Hi, I have seen pictures around the web of people having black bars when using the multi-view app. Maybe they are using another tv. I have a B7 and the bars are grey.
Every issue I have with the app:
- The top and bottom bars are grey
- You have to turn off hdmi-cec
- Every input shows as 16:9, with black bars if the signal is not 16:9
There doesn't seem to be any 3rd party app alternative available, also I looked into if I could make a webos app but from the few minutes I looked into it, it seems you can not access hdmi inputs from a 3rd party app.
As a last resort, is it possible to downgrade the webos version to one that has the app with black bars?
Playing co-op games in splitscreen from two PCs, each in 8:9 aspect ratio would be cool..
