dual audio channel setting 42LF6500 Player setting dual audio USB input
By DW1
By mean2
By OhmorrowSouthWales
By wallyricks
By MNHL
By Wondering,
- smartshare
- usb
- (and 1 more)
- 1 answer
- 917 views
- 1 reply
- 2,973 views
- 1 answer
- 9,113 views
- 3,321 views
Mano
I am having 42LF6500 TV,
When i use input as USB and the video is having dual audio stream, Please anybody can suggest how to change the audio stream according to convenience?
Regard,
Manoranjan
