By thewookiewon
By joe zx
I have LG oled 55b8pla, it is connected to the net, it has the latest update installed, when I start the web browser application and in the on-screen keyboard I start typing for example the URL of the web page, so instead of the number 1 it displays a number 2, instead of the number 2 a completely different character, etc. etc. etc.
I turned the TV on/off, turned the app on/off, unregistered the remote and registered it again. No effect so far.
Any advice, thanks.
By netsplit
By Lleuadwen
Hi, I hope someone can help. I recently bought this TV but can’t find the Art Gallery app that is supposed to be part of the Home Screen. I have searched in apps but only third party art gallery style apps show. What am I missing here?
By Flavio_S
MichaelFP
My TV is an LG 55B6.
A lot of features require text entry on screen - for example using the webbrowser, or renaming inputs (like "HDMI3" to "Xbox"). I had expected an onscreen keyboard to appear when I'm in a mode where text entry is expected - but it doesn't. Do I need to enable the onscreen keyboard? Or?
TV is updated to latest firmware.
Best regards,
Michael
