Multi-View App Questions
By Trev
1. For well over a year the Antenna Channel Guide has been incomplete. Is there a way to manually update the guide?
The Prime app has suffered from two problems:
2. No subtitle option on movies, fixed by app uninstall/reinstall. Is there an easier fix?
3. 4K movies downgrade to SDR or SD momentarily, app uninstall/reinstall did NOT fix this?
TV software is upto date. Internet speed is good. Cache has been cleared by power disconnect/reconnect.
I have not tried Reset To Original settings, will that wipe out antenna channel & HDMI input name customizations?
Thanks.
By DW1
By The Old Man
Hey LG
Yes I am NOT happy
By Željko2
I own a TV LG oled65c31la.aeu. I am interested in whether it is planned in the next firmware updates to return to multiview the
option of displaying two live channels (antenna dvt2), as it was earlier in webos 2.
Previously, a buffer was created in which terrestrial channels were saved, from where they were marked for display.
By Željko2
Hello everyone.
Thank you.
- 3 answers
- 6,178 views
- 2 answers
- 7,990 views
- 0 replies
- 3,750 views
- 10 replies
- 18,535 views
