Go to solution
Solved by AmrDesign87,
By qix70
Hi, could you help me please?
My code now is 541641992
By SHawk
By Sqwazy
By NaveenKumar
Latest version of sun NXT app version 8.0.20 is not working for web os Tv version 4.4.2-11 plz do the needful full & Airtel Xstream is not found in your web os platform kindly check on that too
By majorusa
- 3.23.24 - Romania- 47LB730v
- 8 replies
- 35,861 views
- 0 replies
- 16,656 views
- 2,360 views
- 0 replies
- 2,097 views
AmrDesign87
Hello Dears,
I have an LG smart TV 43LH590V which has the most updated firmware in m country but I found a newer update for the same model at another country and I need to ask If I used this update will it harm my TV or not.
Appreciating your reply
