By
atcronin
Mitzy
My LGwebos3 suddenly started to display a floating text box that reads " FACTORY MODE [How to go to user mode] Press Instop Key in a remote control." The tv image also suddenly has a green or sometimes blue tint to it and it resets to factory settings every time I turn it off. I have pressed every remote button in search is the Instop Key and checked the user manual... No luck! I bought he T.V. About two months ago. Issue started randomly but have been unable to resolve it. Help please! By the way, the green tint is only there is using coaxial or HDMI but when I access the settings menu of the tv, it looks perfectly fine... Frustrated!
5 answers to this question
