USB Recording Issue
By RJ Fischer
By Regis Wheeler
By Hoghton Jim
Many thanks.
By JasonB
By AMK
Tv model 55UJ630V-TA
Sw version 06.10.50
pcpilot
Why is my recording cut short. I record to a 64gb Sandisk Ultra Flash Drive that is empty, so there is plenty of space. I select the finish time as program end, and yet my recording stops before the program end.
