    • By keshav iyer
    • By alfie
    • By Muser
    • By nkat
      Hello Team,
      I'm unable to play any video  any video on LG TV WebOS browswer.
      I've tried to play
      link hidden, please login to viewm also, but no luck. I've toggled (on and off) the 'Adpative Javascript video stream' settings in browser but no luck.
      Can any one help on this .?
    • Solution For That Pollution
    • By Fletcher
      I have recently purchased an LG 43UH610T television.  I am located in Bali, Indonesia.  Everything seems to be working fine, but when I click on any of the options, such as LGTV, YouTube etc, it tells me I must first consent to the LG Smart TV user agreement.  However, I then get a message saying "Unable to load user agreements - a server error has occurred ......"
      Can you help?
