Delete recording programs
By Hoghton Jim
Many thanks.
By StefanosBand
By Kev999
I can only get the Reminder facility to work on live TV in the lower channels like 1, 2, 3 etc, but rejects attempts to use with the HD channels at 101, 102 etc. Is this normal?
By Nooneuno
Our tv always needs to have the recording volume reset... the problem seems to be that the formatted disk has a small boot partition, about 150 mb, plus a 4 GB "main" volume, and the recording app "sees' the boot partition, and won't "hold" the setting for the main volume...
By fmas2
Hi everyone,
I´ve installed Kodi on LG WebOS. I need to delete some backups that by default are stored in the WebOS root system. I guess it can be done through WebOS Dev Manager but I´ll appreciate any help giving me the path to achieve such backup folder.
Many thanks in advance
Linda King
instructions to delete recorded programs
