A bit later than expected but we’re back! Over 2 months passed since the last release and we’re finally back with a new release called “Cold Brew”. We have been working very hard behind the scenes in the past 2 months!
So you’re asking what we have done? Most importantly we now have an initial setup for camera working on both the N4 and N5 with an initial version of the app written in Qt (QML). It’s still pretty rough, but it will do basics for now.  Further improvements will come once we upgrade Qt to 5.7/5.8.
Behind the scenes we’ve been working on getting our Yocto updated to Pyro. This brings quite some challenges due to glibc (2.24) not being compatible with linux kernels < 3.2. Also the newer systemd version (232) brings some challenges in terms of kernel requirements, but we’ve been able to work around those for now.
For Mako (N4), Hammerhead (N5) this isn’t really a problem because we have a 3.4 based kernel, for the Tenderloin (Touchpad) there are 3.4 based kernels available as well, so we’ll be aiming to migrate to a 3.4 based kernel for Tenderloin.
For Maguro (Galaxy Nexus) the situation is unfortunately more problematic because there’s no real working 3.4 based kernel available currently. It’s therefore likely that as of next release we will be forced to drop support for the Galaxy Nexus.
. There are already a lot of synergies between the various OS-es based on Android and also still quite some minor tweaks for each OS. By joining forces in the project we aim to have a common base for the various Android based OS-es.
We have the following items on our to-do list to focus on:
  • Work on Yocto Pyro upgrade
  • QT 5.7/5.8 Upgrade
  • Various UI tweaks
  • Messaging improvements
  • Camera improvements
Known issues:
  • Node-SQLite3 is currently not working. Components using Node-SQLite3 have switched to an alternative storage method for now.
  • Focus bug on input fields. You can work around this by hiding the virtual keyboard and pressing the input again.
Changelog
Applications:
  • Testr (org.webosports.app.testr): Adds test of HTML5 camera API (navigator.mediaDevices); Removes erroneous component from HTML5 camera test; Camera test works correctly with portrait video; HTML5 camera test: adds list of user media devices & requests rear camera.
  • Camera (org.webosports.app.camera): Initial app writen from scratch in QT.
System Level:
  • qtubuntu-camera: add missing dependencies for Qt.
  • packagegroup-luneos-extended: put the camera recipes in LIBHYBRIS_RDEPENDS.
  • mobile-broadband-provider-info: Add LIC_FILES_CHKSUM.
  • qtbase_git.bbappend: Use = for PACKAGECONFIG_DISTRO.
  • hunspell: remove – it is in meta-oe.
  • mesa: do not move around libGLESv2.so.
  • qtvideo-node: Use webOS-ports repository.
  • meta-webos-ports: Add org.webosports.app.camera and the camera infrastructure packages.
The usual
1.
2. and
3.
Download and Install
Feel free to to get started. Tenderloin, Mako, Hammerhead and Maguro remain our focus for now, but the emulator & Grouper work too.
Please note that in order to use the latest stable builds on the Galaxy Nexus (Maguro), Nexus 4 (Mako) and Nexus 5 (Hammerhead) you need to flash the CM 12.1 images first using CWM/TWRP. In order to do so, you might be required to do a “factory reset” or at least “wipe cache”. CWM/TWRP will indicate when this is needed. After successfully flashing CM 12.1, make sure to boot it at least once before going back to CWM/TWRP to flash the latest LuneOS image! We have provided links to CM 12.1 for these 3 images on our device pages below.
Installation instructions for , , , , and are on the . And remember we .
Don’t forget to contact us with any questions and feel free to . Catch us on Twitter on IRC: Freenode:#webos-ports or email [email protected].
We will see you shortly with a new release!
Related posts:
    • By atcronin
      To deliver innovative heating, ventilation and air conditioning (HVAC) solutions that are Ahead of the Expected, LG continues to push the boundaries of heat pump technology in cold climates. At AHR Expo 2025 in Orlando, Florida, the company showcased its energy-efficient solutions that enhance comfort while hosting a special roundtable on the Consortium for Advanced Heat Pump Research and its vision for the industry. Three LG representatives joined the consortium to bring their knowledge and insights to the table.
      As climate change continues to cause major disruption around the world, the need for high-efficiency heating and cooling systems for all temperatures has been rising. Steve Scarbrough, senior vice president and general manager of LG Air Conditioning Technologies USA, joined the panel to highlight the advantages of LG’s heat pump technology in extreme climates. LG offers a wide lineup of heat pump solutions, including water heaters, boasting its cutting-edge inverter heat pump technology. What’s more, with the introduction of a highly efficient, oil-free inverter centrifugal chiller, LG now supplies 259,000 RT of chilled water to one of the largest data centers in the world. “We are excited to bring new products to market that are customized for all kinds of environments from single small spaces to large-scale industry settings,” said Scarborough.
      Although heat pumps have traditionally been associated with warmer southern climates, LG’s introduction of its Inverter Compressor to the U.S. has allowed it to build a strong lineup of heat pumps that provide effective heating in cold climates. Moreover, LG has expanded its LGRED° (Reliable to Extreme Degrees) Heat Technology to more products, facilitating high-efficiency performance under more challenging conditions.
      LG has successfully constructed substantial networks in heat pump solutions by investing in research and development and strategic partnerships with key industry players. For example, LG established the Consortium for Advanced Heat Pump Research with the University of Alaska network in 2023 to conduct real-life research and testing on various types of heat pumps.
      Sunwoo Kim, professor of Mechanical Engineering at the University of Alaska Fairbanks, said the consortium focuses on minimizing thermal resistance in the outdoor unit’s heat exchanger to maximize heat pump efficiency. Researchers are also trying to uncover innovative ways to integrate heat pumps with existing fossil fuel boilers. “If we have a smart and well-designed hybrid system that optimally balances the heat pump with existing traditional systems, we could significantly reduce costs and carbon dioxide emissions,” said Kim. The University of Alaska’s cold climate heat pump labs in Anchorage opened last December, and is now testing heat pump applications in the real world.
      The partnership with the Universities has already borne fruit. For instance, the first joint project with the University of Alaska Fairbanks has been largely credited for the LG Residential Cold Climate Heat Pump, which won the 2025 AHR Innovation Award. “The consortium aims to become the major hub of research and education in cold climate heating systems,” said Getu Hailu, associate professor of Mechanical Engineering at the University of Alaska Anchorage and faculty advisor for ASHRAE and ASME.
      By constantly promoting deeper discussions to realize its vision for heat pump solutions, LG has once again demonstrated its unwavering dedication to breaking down barriers in cold climate heating while underscoring its status as the leading innovator of heat pumps.
      Consortium’s Real-World Labs in Anchorage and Fairbanks
      Aim to Optimize Heat Pump Performance in Tundra Conditions
      ANCHORAGE, Alaska, Dec. 12, 2024 — The Consortium for Advanced Heat Pump Research, the groundbreaking partnership between LG and the University of Alaska Anchorage (UAA), has opened state-of-the-art, real-world-simulated labs to conduct comprehensive studies on cold-climate heat pump HVAC solutions.
      LG and university researchers will conduct studies in two dedicated cold climate heat pump labs located in Anchorage and Fairbanks. These facilities are configured to replicate home environments, enabling a realistic and practical approach to heat pump research. The labs will utilize a variety of LG’s cutting-edge HVAC solutions, including both ducted and duct-free indoor and outdoor units, to assist in the research.
      The work of the Consortium for Advanced Heat Pump Research exemplifies Alaska Governor Mike Dunleavy’s focus on nurturing impactful technology initiatives built on strong public-private partnerships. “Together, researchers from the University of Alaska Anchorage and global innovator LG Electronics are advancing the state of the art in heat pump technology,” the governor said. “These advanced research labs show how new business and investment in Alaska can have a major impact on our nation and the world.”
      “Heat pump technology is integral to HVAC-related decarbonization efforts, and the research conducted at these new labs will help to further drive progress,” said Chris Ahn, president of LG Eco Solutions USA. “This research into advancing progress in heat pump system technology supports the promotion of clean energy advances that are among the primary targets for IRA (Inflation Reduction Act) funding in most states, including those in colder climates.”
      The Cold Climate Heat Pump Labs in Alaska will leverage LG’s cutting-edge heat pump technology to deliver region-specific comfort solutions designed to reduce dependence on fossil-fuel secondary heating sources. In fact, the Anchorage and Fairbanks labs are committed to further enhancing the capabilities of air-source heat pumps to be the primary source of heating in ambient temperatures as low as -40 degrees Fahrenheit.
      The LG Residential Cold Climate Heat Pump, which was just awarded the 2025 AHR Innovation Award in the Sustainable Solutions category, underscores the company’s ongoing research and development efforts for products under cold conditions.
      “The research conducted between LG Electronics and UAA will provide ground-breaking insight into heat pump technology to create the best performing, most energy efficient solutions possible,” said University of Alaska Anchorage Chancellor Sean Parnell. “We’re proud to bring this cornerstone of our university to the HVAC market with LG.”
      The between LG and UAA, launched a year ago, brings together LG experts, university researchers, local industry and government agencies to drive market transformation through research on heat pump technology and electrification. The new labs christened this week will showcase the breadth of LG’s HVAC product capabilities in heating and cooling, setting new benchmarks for energy efficiency.
      The Alaska consortium is an integral component of LG’s extensive network of heat pump research partnerships across Korea, Europe and China. These collaborations collectively form the Global Consortium for Advanced Heat Pump Research, demonstrating LG’s dedication to broadening its research and development programs. LG’s strategic formation of the consortiums has resulted in a robust, global R&D infrastructure, and the wide-reaching approach equips LG with the capability to develop technologies that cater to the unique climatic and housing conditions regionally.
      For more information about LG’s U.S. air conditioning business, visit
      Award-winning Heat Pump Delivers Advanced Efficiency and
      Heating Performance in Extreme Cold Conditions
      SEOUL, Oct. 29, 2024 — LG Electronics (LG), a leading global player in air conditioning technologies, has been honored with the 2025 AHR Innovation Award in the Sustainable Solutions category for its advanced LG Residential Cold Climate Heat Pump. The award was decided by an independent panel of ASHRAE member judges, who assessed product entries based on their design, creativity, application, value and market impact potential.
      The LG Residential Cold Climate Heat Pump, which will be showcased at the AHR Expo 2025 in Orlando, Florida next February, offers opportunities to reduce energy consumption, contributing to climate change mitigation while improving inhabitants’ comfort.
      Designed specifically for cold regions, LG’s heat pump operates effectively at temperatures as low as negative 35 degrees Celsius (negative 31 degrees Fahrenheit). It retains full heating capacity at negative 25 degrees Celsius (negative 13 degrees Fahrenheit) and functions at 70 percent capacity at negative 35 degrees Celsius (negative 31 degrees Fahrenheit). Additionally, the innovative heat pump incorporates a refrigerant cycle that prevents frost accumulation on the outdoor heat exchanger, thereby enhancing heating performance. The impressive solution is also equipped with a high-capacity, high-efficiency twin rotary inverter compressor that uses low Global Warming Potential (GWP) R32 (GWP 675) refrigerant, available with HSPF2 13.4 Btu/Wh and 13.6 kBtu/h.
      “The recognition from ASHRAE and AHR reflects LG’s ongoing dedication to HVAC technological innovation and electrification,” said James Lee, head of the Air Solution Business Unit at LG Home Appliance & Air Solution Company. “The Residential Cold Climate Heat Pump is a solution that can withstand extreme cold weather conditions and help improve energy efficiency in homes. Our focus remains on creating more environmentally responsible solutions that align with consumer needs while simultaneously reducing our global environmental footprint.”
      LG’s comprehensive suite of heating and cooling solutions for commercial, light-commercial and residential applications continues to receive industry recognition. This is largely due to LG’s consistent efforts to provide innovative HVAC solutions leveraging the company’s advanced core technologies, which elevate performance and support the move to electrification.
      LG prioritizes heat pump advancement as a key component of the U.S.’s climate improvement efforts. Several states have committed to improving decarbonization, setting a goal for heat pumps to constitute at least 65 percent of all new HVAC and hot water heating systems by the end of the decade.
      LG’s commitment to these broader goals is further demonstrated by its leadership of the Consortium for Advanced Heat Pump Research, founded in collaboration with the University of Alaska to establish an Advanced Cold Climate Heat Pump Laboratory in Alaska. LG has also set up a global R&D triangle connecting North America, Europe (Oslo, Norway) and Asia (Harbin, China), with the aim of accelerating the development of high-performance heat pumps for regions that endure extreme cold.
      “We understand the need to develop and validate products under extreme cold conditions, and the award-winning LG Residential Cold Climate Heat Pump is a testament to our ongoing efforts in this important area,” added Lee. “By minimizing reliance on fossil fuel-driven heating systems and cutting down on any supplementary back-up heating, the heat pump reduces environmental impacts and supports the larger decarbonization and electrification movements.”
    • By pivotCE
      Picture credit: from Pixabay
