43uh603v Bluetooth question
By JamesH
By Fredrik Andersson
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Kane Murphy
By janisad
I have an LG 32LJ610V TV.
Kovács Zsolt
Hi! I have an Lg 43uh603v tv, and I bought a magic remote MR-650. I know that tv hasn't bluetooth, but I need to use the remote. My question is the AN-WF 500 supported my tv and remote, or is there other way to connect the magic remote to the tv? Is there a bluetooth dongle that supported LG tv's?
