I have a 55UH650V Smart TV Which i'm lovin...  But I can't seem to get the live tv pause to work with a USB drive..   I bought a 64GB USB 3.0 drive which works for general program recording and playing music, picture files on the TV etc... But when I try to pause live tv it says it cant work with this drive choose another?
Is there anywhere that specifically advises on USB spec for this function?
Kinda think it should be in the manual but i cant find it... :(
8 answers to this question
I tried many as we have lots of choice at work without buying them, no jump drives worked, even SAMSUNG T1 256GB.
Only spinning disks or SSD mounted in a 2.5" case.
  • Like 2
I had same problem.  I can record onto USB  but not use live playback. Emailed LG. They said for live playback you need an external hard drive.  Bought the cheapest one I could find and Live Playback now works fine
I've just bought these ln Amazon for £24 and it's working great
Western Digital Green 120 GB Internal SSD 2.5 Inch SATA
And
USB 3.0 to SATA22P Hard Drive Adapter Cable for 2.5" SSD/HDD Hard Disks - SATA to USB 3.0 External Converter and Cable,USB 3.0-SATA III converter
And
Expand
I can confirm that these work perfectly. I can pause live tv with no problems. I also can confirm that the 240 GB version works as well (£28).
And
Expand
I'm considering purchasing these too but have just noticed that the box states they are for 'light and casual use'. Have you had any problems with them?
    • By qix70
      Hi, could you help me please?
      My code now is 541641992
    • By Charlie F
      Charlie
    • By JamieG
    • By mr.porter
      Hello
      Question about new LG WebOS tv's, anyone noticed when pausing live TV ( live playback) on Webos 5.3 ( GX ) that recording is reset when changing channels.
      Meaning if you have paused tv and then changed the channel the playback recording is lost / reset to 0 minutes.
      I've have two LG tv's before the GX that didn't do this current this have one.
