silverlinght, flash player
There is Nothing smart in these TVs, the store is very empty no useful applications, and for the web no flash, tell me what make these TVs smart !!!!
WebOS needs a very quick update about at least the flash in the web browser
    • By Jack1151
    • By mycop
      Greetings.
    • By wallyricks
    • By MNHL
    • By Matt Moran
      Matt
