Please help re user agreement not working
By Hasan Ghasabi-Oskoei
Can you help?
By Roy Brown
By Rex G
By ato53
I have a new C4 TV.
Thanks for the follow-up
Drewiemaxx
Hi all I'm a new member have the lg43uh661 which was working fine until last night. Couldn't access my PS3 or bluray player or fire stick. Checked connections and turned everything off. Restart still same. Do factory reset and thus agreement working issue still there despite repeated attempts. Reset again. Turned wifi off and on. Still same. Any advice greatly appreciated thanks.
3 answers to this question
