Hello
I have a question regarding an external hardrive.
i have a 49UH603T tv that is using LG webos 3.0 at night i leave my 2TB external hardrive connected and running cartoons. i select the timer to turn off the tv after a few hours.  once the tv turns off by itself. would this effect or corrupt the hard drive. i am aware that you can safely remove the usb drive. any feedback would help. thanks.
    • By mycop
      Greetings.
    • By bos2prov
    • By Fricassee
    • By Wondering
    • By Velvet_Noir
      Hi, I have the option to right click and pick the subtitles on my Mac when watching movies in the VLC Player, but I can’t do this on the LG OLED, though. I already renamed the subtitle file to be the exact same as the video file and I did have the SRT file in the same folder where the movie is. However, when I connect the hard drive to the TV, the subtitle still doesn't appear. The format of my hardrive is NTFS. Can anyone please offer some advice?
