- 7
how to download hotstar app in lg store ???
By Bhanu Kumar
By AJO
By Ahmad Baeisa
I bought an lg pf50kg smart projector and can't find netflix, youtube and no app store so i paid for a projector that should be smart and ended up having a normal one this is cheating lg .
By Nihar Ranjan Dash
The international content on JioCinema and Hotstar apps are not playing. No issues with Indian content in Hindi or other regional languages. But English, Korean, and Japanese content are not playing. Specifically, I want to play Disney content on Hotstar and HBO content on JioCinema App.
I tried resetting all configurations and reinstalling the applications and re-logging into the apps. Still, the issue persists. I tried switching off the TV and tried pressing the power button for complete discharge and rebooting my router, but the same issue persists.
**I found a workaround though, changing the wifi network or using a mobile hotspot on TV and then all content plays well even if I revert to my primary Airtel wifi, It still plays. but the next day the same issue continues.
It's an overhead to switch the wifi every time I want to watch Hollywood titles. Certainly, it's not the experience I want with a TV of a hefty price tag. No other devices (Mac, ios, android, windows, Android TV) have this problem. Also, it's not the wifi issue, as I can watch the same titles on other devices. The LG TV also doesn't have the capability to remember a few WiFi networks to ease this workaround of switching networks.
Alas, Nobody informed me about this issue earlier while making the purchase. Now such pricey TVs shouldn't have these issues at all. Kindly let me know If there is a permanent fix for this issue.
By akhil7j
By Wondering,
- smartshare
- usb
- (and 1 more)
- 1 answer
- 942 views
- 2 answers
- 7,354 views
- 6,049 views
- 2,680 views
care number
3 answers to this question
