Regional settings not saving
By Cody94549
By Low Grade
many thanks in advance😃
By Magsing
By Itachi3431
Hi all,
P.S., running latest Web OS
By nester
it would be great if there was some kind of “percentage” slider or just adjusted power saving settings. Right now, there is too much difference between maximum and medium power saving mode - maximum is too dark and medium is too bright, with no way to be set between. Also difference between two brightest is not so much big.
Second idea is to bring this setting somewhere closer (higher) in options. In my opinion, it might be the often changed setting by users. I use to change it regularly, especially between day and night.
- 5 replies
- 4,194 views
- 0 replies
- 2,071 views
- 2,522 views
- 1 answer
- 11,668 views
BataviaDan
I have webOS TV UH6100, software 04.31.10.
Sometime in the last week something happened that caused my date, time, and location to be wonky. I can't set them, and automate detect isn't working. Same with allow automatic updates. It says "may take a few seconds" but i've waited 15 minutes to 30 minutes with nothing happening. Network connection is good - it is able to connect (according to the software).
I've tried reset factory settings to no avail, because it says the tv will now restart - i get the spinning circle of dots - but it never restarts. When I turn the tv off and back on, it's still in the same state.
None of the apps will go anywhere either.
Any ideas? Thanks for your help in advance
