Netflix app error
By Marko00
only with cancel button.
How to fix it?
By leader6234
Hey guys !!!
Thanks in advance !!!
By Muser
By Nicola123
wachman
For the past few days I've been getting a Netflix app error. The error says we're having trouble playing this title right now please try again later or select a different title. btw-pm-100 (5.2.12).
I have an LG 55uh6090 with webos 3.0 up to date and I've already tried unplugging it to restart it but the app still doesn't work. Does anyone know what I should do?
Sent from my VS988 using Tapatalk
