Start in Smart TV Interface?
By Will M
By Lesbo
By Rex G
DekHog
Does anyone know if it's possible for my LG to start from standby into the Smart/Web OS interface?
We only use the smart TV section, and it's exceptionally annoying that it starts in HDMI 1 every time..... there are no inputs attached apart from the network cable so it finds nothing.......
Sent from my ONEPLUS A3003 using Tapatalk
