Issue with YouTube. Now it's OK.
Go to solution Solved by Alex,
  • Solution
On 6/21/2017 at 0:47 PM, JorgeR-VLC-es said:
Today, I were prompted to upgrade YouTube.  After upgrade, YouTube doesn't play any video. Any idea?
At the next day, it is running properly again.
That's interesting, at least its working now. Might have been an internet connection issue.
    • By RJ Fischer
    • By Lee Magee
    • By Will M
    • By David Joseph
    • By Владимир Морозов
