Problems with HTML5
By John Nguyen
By Nick Payne
By LG tv fan
Recently live channels stopped working with an error every 2-3 seconds.
Older media is still playing.
Now I noticed that new media like today's news aren't playing either. Same error.
News from Friday 3rd may still work.
Have tried on 2 LG tvs.. Oled from 2018 and LCD from 2020
By Trollpaw
Hello.
I have an issue with my tv losing connection.
It seems like it's not uncommon for it to happen from time to time. but is has gotten worse the past couple of months. It can happen several times per day. usually when using netflix, but it can happen whenever.
i regularly lose the bluetooth connection to my magic remote, and a lot of the times when this happens i also lose connection with the wifi, The remote is still usable, in a somewhat limited capacity(no pointer, and need to have a more clear line of sight to the tv)
when the wifi disconnects it sometimes connects automatically, sometimes i have to manually connect it again, and sometimes the wifi function gets turned off, and can't be turned on again. usually this solves itself by putting the tv on standby and starting it again. using cable instead of wifi is not possible for the moment.
the remote. what usually works is pulling the plug on the tv for a while, and then it functions again. sometimes it's enough just putting it in standby mode for a minute or 2. sometimes i have to unregister and re-register the remote. THere's not one thing that works all of the time, so i have to try several things, but i've found that pulling the plug usually works best.
it's rarely enough to un-register and re-register the remote, i usually have to either put the tv in standby for a couple of minutes, or pull the plug
it's getting very frustrating dealing with this, so i'm asking to see if anyone knows what to do as a more permanent solution. i have no issue with doing factory resets or anything like that.
Regards
Stoffe
Danny
I have a LG webos TV UF770V which I have had for over a year now, I have been using a site to stream movies and it has been fine up until recently where it now comes up with "HTML5: Video file not found"
this still works fine on my phone, Ipad and PC which I do understand run a much better system than the limited version you get with a TV but I am just confused as to why it has happened now when it has been fine all this time.
Does anyone have any ideas on how to rectify this?
