LG 4k UHD 49UH6030 t.v. internet connection speed
With a LAN wire internet connection what is the highest download speed this t.v. can receive?  Mine seems to get only about a 30-40mbps download speed, but sometimes less.
What does the connection cap at?
Manual shows information for a wireless connection, but can't make sense of the explaining of the chart anyways.
Contacted LG by phone and email, no response from email at all, phone support just seem to know nothing about it and said wait for the email response.
Its be almost 2 weeks, can't anyone verify if this T.V. can get a higher internet connection download speed (like 100 - 150 mbps) ?
    • By Mandx
    • By akhil7j
    • By Trung Hiếu Trần
      Specs: LG OLED 55C3
      Router speed: 250mbps
      System: webOS 2.3
      Any ideas on how to fix it?
    • By makem
      I have a  LG OLED55C14LB WebOS TV in the same room as my xubuntu desktop computer and router.
    • By Musica napoli live e anteprime
      Hi, I would like to know if it is possible to exceed a speed of 100 mb/s with an Ethernet adapter for LG webos 3.5 TV and if so which adapter? I tried the one from Cable Matters but nothing
