ST_20170628_VCLG28_3230222.jpg?itok=_zsq
The 4K resolution lets you see every tiny detail and colors pop out vividly
LG has surpassed itself with its latest flagship W7 Oled television set.
I am not saying this lightly, because its flagship last year, the G6, was such a head-turner. With its Oled (organic light-emitting diode) panel bonded to an oversized glass backing, the G6 gave the impression that its screen was suspended in mid-air.
The new Signature W7 Oled TV set takes this further by removing the glass backing. Its ultra-thin Oled panel (2.57mm) is, instead, attached to the wall using magnetic brackets. A flat umbilical cable connects this screen to the included soundbar, where the TV set's electronics reside.
Paint this cable the same shade as your wall and you won't be able to see the cable from a distance.
This "picture-on-wall" design makes the W7 look like a picture frame, especially if you turn on the Oled Gallery screensaver that cycles through renowned paintings from famous artists on its 65-inch screen.
LG could not resist showboating - when you turn on the TV set, two circular speakers rise from both ends of the soundbar, accompanied by an audio flourish and a Knight Rider-like red LED light at its front.
This soundbar is clearly not your average TV speaker system, as it produces clear and balanced audio. I was surprised by its competent bass performance, though it was better at the mids and highs. It also holds all the connectors, including four HDMI 2.0a ports that are required for High Dynamic Range (HDR) content.
The W7 supports two existing HDR formats - HDR10 and Dolby Vision - that make movies look more realistic and truer to life. It also supports two new formats - Hybrid Log-Gamma for live HDR TV broadcasts and Advanced HDR by Technicolor - though there is no content for these yet.
Despite an increase in the amount of HDR content from providers like Amazon, Netflix and even YouTube, these videos are still relatively few and far between. For non-HDR content, the W7 has an HDR Effect option that increases the brightness and contrast to approximate HDR. While it does make your average TV shows look brighter and more vivid, it is not quite the same as the real thing.
The difference HDR makes can be seen in the opening musical routine in La La Land.
The sunlight glinting off the cars stuck in a traffic jam almost made my eyes squint, helped by the fact that the W7 is 25 per cent brighter than last year's models. But the bright sunlight also appeared to cast shadows that slightly obscured the faces of the singers.
As expected of an Oled TV set, the W7 showed its mettle in dark scenes with few light sources, such as the movie's final sequence, where the actors danced in the dark, illuminated only by multiple tiny lights. Thanks to its pixel-dimming feature, the dark parts of the scene remain inky black, with no halo effect from the lights.
The W7 also looked spectacular while playing the Planet Earth II documentary series. Colours pop out vividly while the 4K resolution lets you see every tiny detail. LG's TruMotion feature at low setting also reduces motion blurring without looking unnatural.
The catchphrase for the updated WebOS 3.5 platform on the W7 is "make TV simple again". For some reason, LG thinks that means having new, niche features, like being able to zoom in on a specific area of a video (Magic Zoom) that I tried once and found it more gimmicky than useful.
Nevertheless, WebOS remains one of the best smart-TV platforms I have tested, even if it has far fewer apps than Android TV. And LG did make some useful improvements. For instance, you can bind shortcuts for apps and certain functions to the number keys on the remote control for quick access. Since the W7's Magic Remote control already has Netflix and Amazon buttons, I used the number keys for YouTube and the built-in video player.
The Magic Remote control is similar to the version from last year. Its best feature remains the air-mouse function that lets you move an onscreen cursor by waving the remote control. A more compact Slim Remote control is also included.
At $12,888, the W7 is in a league of its own in terms of pricing. Its unique design is also possibly its biggest drawback. It has to be wall-mounted, which may not be for everyone. Its soundbar is also unlikely to satisfy audiophiles.
As LG uses similar Oled panels for all its Oled TV sets, those looking for a more affordable model may want to look at the entry-level C7, which costs $7,288 for the 65-inch version and $4,688 for the 55-inch model respectively.
•Verdict: The W7 is not without its drawbacks, but it can be a spectacular centrepiece in the right living room. I cannot wait to find out what LG will come up with next year to top the W7.
Source:
    • By Nick Payne
      We have a 65" G1 OLED set. Lately (like the past couple of months), at irregular intervals while the set is on, it will power itself down without any input from the remote. Happens maybe once every two or three days. Powering it on again using the remote always brings it back to life OK. Unsure whether this is a hardware or software problem, and can't see how I could determine whether it's one or the other. Any suggestions? The TV is current with whatever the lastest level of FW is - I just checked in settings and was told there were no updates available.
    • By OliverRC
      Dominating With Over 52.4 Percent Market Share in 2024,
      Company Reinforces Its Unrivaled Leadership in Premium TVs
      SEOUL, March 12, 2025 — LG Electronics (LG) has reaffirmed its dominance in the premium TV market, leading global OLED TV shipments in 2024 with over 52.4 percent of the market share. For 12 consecutive years, LG has commanded the global OLED TV market, continually enhancing the TV experience with audiovisual excellence and AI-powered personalization, embodying the true essence of OLED technology with perfect black levels and enhanced brightness.
      According to market research firm Omdia, LG secured the top spot in the global OLED TV market last year, shipping an impressive 3.18 million OLED TV units. Notably, fourth-quarter shipments alone surpassed 1.1 million units, showcasing the company’s ability to deliver cutting-edge technology that meets evolving consumer preferences.
      OLED TVs accounted for 45 percent of the premium TV market in 2023, based on models priced at USD 1,500 and above, marking an 8.5 percentage point increase from the previous year. With the market expected to exceed 50 percent this year, LG is committed to driving innovation and maintaining its leadership in the OLED TV industry.
      As demand for larger screens continues to rise, the number of ultra-large OLED TV shipments has also increased, comprising 16 percent of the entire OLED TV market. LG remains at the forefront, dominating the market with a 57.5 percent share in 2024 for OLED screens of 75 inches and above, including a compelling selection of 77-inch, 83-inch, 88-inch and 97-inch models.
      Backed by over a decade of OLED innovation, LG is set to introduce its latest OLED TVs, featuring advancements like wireless transmission of audio and visual content up to 4K 144Hz with no latency or loss in quality, AI-powered personalization through webOS, and superior picture quality with enhanced brightness and perfect black levels for a truly exceptional viewing experience.
      Global TV shipments reached 208.8 million units last year, marking a return to growth after three years, with OLED TV shipments rising 8 percent year-on-year to 6.07 million units. Additionally, LG’s total TV shipments across both OLED and LCD models reached 22.6 million units last year, representing 16.1 percent of global TV market revenue.
      Have you ever wondered how many LG OLED TVs are shipped every year? 100 thousand units perhaps, maybe as much as a million? In the first half of 2023, LG recorded over 1.33 million shipments of its stunning OLED TVs, setting new benchmarks and records its competitors can only dream of.
      link hidden, please login to view, LG captured over 55 percent of the global OLED TV market in the first six months based on total shipments. As a renowned OLED TV leader now celebrating 10 years of innovation in this space, LG has once again defended its premium TV crown while further cementing LG OLED TV’s status as the pinnacle of premium TVs.
      The “bigger the better” trend continues to prevail in the TV market, which is great news for LG. As more and more people desire larger TVs for their living spaces, models of 75 inches or larger accounted for a remarkable 11.4 percent share of total OLED TVs sold, while shipments’ yearly average growth rate topped 90 percent over the past five years. Staying on top of this growing trend, LG is resuming its dominance in the market with an outstanding 64.2 percent share in total shipments of OLED TVs over 75 inches.
      LG is targeting this new demand for large and premium TVs in the second half of 2023 with the groundbreaking TV (model 97M3) it unveiled in July, which boasts the world’s first 4K 120Hz wireless solution that makes it easy for customers to achieve their dream interior.
      Not one to be confined, LG unleashed a tidal wave of 10 million TV units (OLED and LCD) on the world, which has helped the company carve out a 16.2 percent share of revenue for itself in the global TV market.
      Despite facing a downturn in the global TV market, LG persisted in strengthening its inventory management and securing higher profits while actively pursuing a strategic approach for its premium and ultra-large displays. And this commitment has paid off substantially, with its LG OLED TVs now accounting for around 30 percent of the company’s overall revenue generated from TV sets.
      TV shipments totaled over 92 million units in the first half of 2023, matching last year’s first half performance. The OLED TV segment, which has been led by LG for a number of years, has already passed the 2 million shipments mark this year, which bodes well for the rest of 2023.
      OLED TVs are continuing their takeover of the global TV market after capturing 9.3 percent of all revenue in the first half. Meanwhile, Omdia predicts that OLED TVs are set to shine even brighter, projecting at least a 43 percent revenue share among premium TVs priced above USD 1,500.
      Find all the latest news on the home entertainment business and learn more about its world-leading innovations on the LG Newsroom.
