Lg 3d smart tv megic remote not working
By Roy Brown
By Will M
By Lesbo
By Rex G
By Mogens
Kind regards
Mogens
Monty Rethabile Mahlatsi
My LG 3D Smart tv(42LB652T) is unable to register my smart remote. I reseted the remote,changed batteries and even turn the tv on and off but the remote only says "failed to register megic remote, please try again later" remote still works but unable to access other features due to it not pairing. Un able to use the ok button as it trys to pair the remote evey time i press it. Please assist?
