recordings on WebOS tv failing with "unable to load"
By Hasan Ghasabi-Oskoei
Can you help?
By Roy Brown
By Khelben Arunsun
By magicschooldropout9
By AmuLulu
- 3 answers
- 530 views
By Wondering,
- smartshare
- usb
- (and 1 more)
- 1 answer
- 932 views
- 1 answer
- 1,560 views
- 1 reply
- 2,990 views
Peter Johnson
I am trying to record terrestrial digital programs from my 2016 LG webosTV to a USB stick- if I set up a few programs to record, a few work, but after a day or two it will fail. and from that point all will fail.
The TV does still try to record, as I can see it pop up a notification if I am watching, but nothing is recorded. (No error message is shown then.)
If I look at the "scheduled recordings" page, it shows an error, and "Unable to load" for the start and end time of the failed show.
If I go to "recording history" for that show, I see a message saying "incomplete, Cable/broadcast service changed programming" but that can't be the case for so many different shows,
There is plenty of space on the USB stick.
I have tried LG support, but they can't tell me what the message means, and suggest returning the TV for repair.
As a side note: I don't usually watch terrestrial TV through the television- we still use Sky (which is why I want to get this working!) I only say that in case it was a reason that show schedule information is not being updated.
Any help or suggestions gratefully received.
6 answers to this question
