Company Offers Extensive Range of High-efficiency Heating Solutions for
Diverse Residential and Commercial Needs
SEOUL, March 17, 2025 — LG Electronics (LG) is presenting its latest heating, ventilation and air conditioning (HVAC) solutions tailored for the European market at the International Trade Fair for Sanitation, Heating and Air (ISH) 2025, taking place in Frankfurt, Germany, from March 17-21. LG’s showcase features high-efficiency solutions optimized for both commercial and residential spaces, including the large-capacity Monobloc G Air-to-Water Heat Pump (AWHP). The comprehensive exhibit underscores the company’s commitment to electrification and decarbonization, as well as its focus on providing first-class performance, flexibility and ease-of-installation.
Enhanced Energy Efficiency and Advanced Heating with the New Therma V R290
Located at the entrance of LG’s exhibition booth, the Hero zone introduces visitors to the new Therma V R290 Monobloc. This impressive residential solution boasts excellent energy efficiency and a premium European design. Winner of a 2024 International Design Excellence Award and rated “Good” by the German consumer organization Stiftung Warentest, the new Therma V utilizes R290 refrigerant, which has a low Global Warming Potential of 3. Designed to reduce energy usage and environmental impact, LG’s solution harnesses heat from the air to reduce carbon emissions and achieve an A+++ energy rating.1
Made to withstand Europe’s tough winter conditions, the new Therma V AWHP leverages LG’s proprietary scroll compressor to deliver exceptional energy efficiency and a strong, reliable performance. The positioning of the compressor at a lower-than-usual height within the unit itself contributes to the Therma V’s ability to function at 100 percent capacity, even at temperatures as low as minus 15 degrees Celsius. It also leads to improved energy savings and operational stability. With a noise level of just 50 A-weighted decibels in Low Noise Mode, the Therma V produces minimal vibrations, helping to create a relaxing and peaceful environment both inside and outside the home.2
In the multi-residential and large-scale housing zone, LG is presenting the Monobloc G large capacity AWHP and the Cascade Control Unit. The energy-efficient Cascade system offers flexible scalability, allowing the addition of up to eight units to cope with increased heating demand. The Cascade provides multiple benefits for multi-family dwellings, including low-noise operation, a space-saving design and continuous operation via backup systems.
Efficient Heating and Cooling Solutions for Modern Homes and Multi-Residential Buildings
LG’s ISH exhibition includes a variety of residential heating solutions that have been purpose-built for European kitchens, laundry rooms and living areas. The company’s latest Heat Pump Water Heaters (HPWH) with R290 refrigerant, which use electricity as well as energy from the air to heat water, offer higher efficiency than conventional electric or gas water heaters. Smart Grid ready, HPWHs can enhance energy efficiency by adjusting operation in response to electricity demand signals. Furthermore, to maximize suitability for a wider range of installation environments, LG’s water heaters are available in both floor-standing and wall-mounted types.
The new DUALCOOL AI Air with AI DUAL Inverter provides optimized air conditioning by detecting the ambient temperature of a space and intelligently adjusting the set temperature and airflow direction and speed. The company offers three different DUALCOOL AI AIR indoor units with R290 refrigerant to suit any home, with each variant offering easy installation and maximum space efficiency.
Advanced Commercial HVAC Solutions for Effective Energy Management
Additionally, LG is introducing a range of cutting-edge commercial heating solutions at ISH. A standout among these is the LG Inverter Scroll Chiller – an energy-efficient system for heating (and cooling) commercial facilities. Equipped with twin inverter scroll compressors and plate-type heat exchangers, the LG Inverter Scroll Chiller offers a wide operating frequency range and excellent heat transfer efficiency. When integrated with LG’s Building Energy Control (BECON) CPM system, the chiller provides seamless control of all connected fan coil units and air conditioning systems. BECON CPM monitors and adjusts various control elements to maintain peak efficiency and allows users to track system status in real time. It even sends users helpful alerts if an issue arises, so that appropriate action can be taken to quickly remedy the situation. Set to launch in Europe, BECON CPM also employs LG’s advanced AI-based technology to prevent energy waste and to simplify control for system managers.
One of the many highlights of LG’s booth is the R32 Variable Refrigerant Flow (VRF)-based integrated solution package. The LG Multi V i, an all-electric VRF solution, intelligently manages performance according to environmental changes and helps prevent unnecessary energy consumption. When connected to the Hydro Kit, the Multi V i supports floor heating and hot water supply while its compatibility with Air Handling Unit applications from various companies enables it to serve large warehouses and other specialized business-to-business environments. Along with exceptional scalability, the company’s all-electric system offers efficient management with convenient Smart Control features. Powered by LG’s advanced AI Engine, these features analyze the operational data of the Multi V i to improve indoor comfort and create significant energy savings.
Also at ISH 2025, LG is introducing the LG All Stars program: a rewards program for HVAC installers that offers exclusive benefits, educational opportunities, continuous support and the chance to be a part of a growing professional network. Accessible via the LG All Stars app, the All Stars program lets users take advantage of the BECON Cloud maintenance service, which ensures fast and accurate issue diagnosis and allows the remote monitoring of connected heating systems from any location.
“The groundbreaking LG residential and commercial HVAC solutions on show at ISH 2025 demonstrate our commitment to delivering energy-efficient, high-performance heating systems for the European market,” said James Lee, president of the LG ES Company. “As a key player in the global shift towards electrification, and a trusted provider of advanced HVAC solutions, LG will continue to pursue innovation that maximizes customer value while minimizing environmental impact.”
Visitors to ISH 2025 can experience the latest LG HVAC solutions at the company’s exhibition booth (E69, 12.1 Hall, Messe Frankfurt).
1 Seasonal space heating efficiency rating of A+++ at 35 degrees Celsius LWT and A+++ at 55 degrees Celsius LWT, in accordance with EN 14825 in the European Commission Regulation (EU).
2 The sound power level of 50 decibels A at 9 kilowatts in Low Noise Mode was measured in accordance with EN 12102-1 and ISO 9614 under an outdoor air temperature of 2 degrees Celsius. This mode reduces noise by limiting the compressor frequency and fan speed, which may affect performance.
By Prakash Sahoo
Hi Team,
Prakash Sahoo
LG is dedicated to enriching the lives of people in the communities where it operates. Recently, LG offices in Vietnam and Thailand made significant contributions by donating various LG products to support local initiatives. These acts of generosity underscore LG’s global commitment to corporate social responsibility and demonstrate the positive impact a company can have when it invests in the well-being of its local communities.
In Vietnam, the Lunar New Year, or Tet, is a time of family reunions and shared experiences, with television playing a central role in these celebrations. To enhance the Tet experience for the people of Yen Bai Province, LG Vietnam donated 40 LG TVs to families who suffered significant losses during Typhoon Yagi. As part of its annual campaign, “Tet Nha la Tet Nhat” (Family Tet is the Best Tet), LG Vietnam extended support to 40 households facing severe hardships, including families of war veterans and those with meritorious services to the revolution, in the districts of Van Yen, Luc Yen and Tran Yen.
No district suffered the wrath of Typhoon Yagi more than Van Yen, where the natural disaster destroyed vast areas, damaging, eroding or completely destroying countless houses. Large stretches of cropland along the rivers and streams were submerged in deep water, causing havoc to the lives and livelihoods of the locals. Last year,
link hidden, please login to views to provide much-needed assistance to these people.
Since Tet 2024, LG kicked off the “Tet Nha la Tet Nhat” campaign, named after the respected proverb “Tet Nhat.” “Tet” represents a meaningful time of year when Vietnamese people prepare the best for their families, while “Nhat,” meaning “best,” aligns with LG OLED TV’s global leadership and the world-class quality of its advanced products.
The Year of the Snake marks 30 years of LG’s presence in Vietnam, symbolizing a deep commitment to continuous innovation and creative solutions for smart living. This milestone reflects LG’s dedication to improving the lives of Vietnamese customers and fulfilling its Life’s Good vision.
In Thailand, LG recently donated 50 LG gram laptops to the Thailand Collaboration for Education (TCFE) program, an initiative of the Yuvabadhana Foundation. This donation, valued at over 2,301,000 baht (USD 68,000), will benefit over 400 students at Nikomphimaisuksa School in Nakhon Ratchasima province and Piyabut School in Lopburi province, both of which lack adequate computer equipment for effective digital learning.
The donated laptops are high-performance, lightweight LG gram models equipped with Intel Core Ultra 5 Processors, making them ideal for modern AI software applications. Students in lower secondary school (Mathayom 1-3) will use these laptops to access digital curricula in science, mathematics and English. Upper secondary students (Mathayom 4-6) will leverage the laptops’ AI capabilities for advanced learning, including data analysis and enhanced comprehension.
The TCFE program aims to reduce educational inequality and promote sustainable education in Thailand by focusing on four key areas: educational accessibility, teaching and learning quality development, life skills and moral cultivation and nutrition support. LG’s laptop donation directly supports two of these areas: improving access to education by providing equipment to remote schools and enhancing teaching and learning quality by enabling digital curriculum implementation.
This donation reflects LG’s belief in the transformative power of AI in education and its commitment to ensuring all Thai youth have access to this technology. The company views this donation as part of its ongoing support for AI education in Thailand, which includes equipment donations, expertise sharing and future initiatives.
From providing essential appliances to enhancing educational opportunities, LG Vietnam and LG Thailand are actively making a difference in the lives of those around them. To learn more about the activities of LG offices around the globe, visit the .
Contributed by LG Vietnam and LG Thailand
By Владимир Морозов
- 1,350 views
- 47 answers
- 104,706 views
- 1 answer
- 3,683 views
- 0 replies
- 1,857 views
