Unable to record
By Hasan Ghasabi-Oskoei
Can you help?
By JamieG
By keshav iyer
By alfie
By SergeNault
Hello all, quick question,
I have an LG Smart TV, with the latest firmware ( 04.50.56), that is connected to a PVR ( Cisco). That PVR, via a cable company called Videotron, has about 50 of exercise videos of 20 minutes recorded over that past years. I wish to move away from my existing TV provider, but before doing so, I'm trying to figure out how to export the videos into an external drive ( USB, cloud) , so that I can re-use them. Some people have suggested to remove the hard drive from the PVR and export to a USB, but those files are encrypted. So outside of using my Iphone and actually record the shows, is there a better quality way of doiing it? I'm thinking some sort of app, that the TV can download, and then record to a USB drive for example. Thanks for sharing any positive outcome.
Serge
Rtab Blue
I use to be able to record on my LB65 Smart TV, but not anymore. When I press the ok button nothing happens. My programme tuning and programme manager also greyed out. Trying to reset to factory settings by pressing the ok button on my magic remote and ok button on tv does nothing. Is my tv Hacked? What to for?
