Magic remote refuses to wake up
By RJ Fischer
By Lesbo
By u84six
By joepineapples90
So I'm thinking about buying an oled65g46ls, however the included 'magic' remote would be useless to me, due to health issues (tremors). So my question is, do any other LG remotes work with the G4?.
Dennis Hansen
Does anyone have a solution for how to get the magic remote to wake up instantly?
I have to wait for ar least a minute for the pointer to appear on screen.
6 answers to this question
