smart iptv app
By Adnan Ali
Hi, I’m planning to develop an IPTV app for webOS and would like to know the best technology stack to use. Should I go with a hosted URL or develop it using native code?
By Will M
By Lesbo
geordiewhite
Hi Im trying to get my friends smart iptv app to work on his tv, he bought his tv in 2011. i have loaded the smart iptv app with the relevant sources but when i come to view the channels it says it is connecting but never does, i have set up his tv settings in the iptv app the same as mine but having no joy, does any member know if i should change some settings as his tv is a bit older than mine.regards John
