By MURAD
By dzoole
Silly question by me, but it seems that I can't find subtitle button on LG ThinQ app on my mobile phone? Anyone knows if we can select subtitles through the LG ThinQ app?
By BGee
On my LG 60SJ850T, Watching Horizon from AppleTV streaming service. Western with some scenes with Apache language being spoken. No subtitles appearing. When CC is on, see “foreign language being spoken”. When viewed on iPhone, there are subtitles. Have tried same movie using chrome cast TV, and casting from iPhone to Apple TV device. Never get subtitles. Verified subtitles work when I stream to same chromecast TV connected to a different TV.
reset LG TV to factory settings after trying all available CC and subtitle settings on TV. Still no subtitles.
By Danster75
Hi all,
I'm Danny and have a problem with my LG OLED65C8;
since a few months when playing movies, either from my Syno NAS or just plain USB, subtitles are being displayed double (over or above eachother) or are displayed for sometimes minutes after the sentence's been spoken. The videofiles haven't got any hardcoded subs but either subs included in the mkv container or as separate srt of ssa file. Disabling subs removes the display of subs, enabling subs results in double or persistent subs.
Subtitles have been disabled in the accessability menu, factory reset did not help.
I searched but as far as I can see this problem has not been discussed yet, also googled and never came across this problem. Perhaps someone here can help?
Kind regards, Danny
SOLUTION, for me at least:
I used ColorControl to reboot the TV. It's weird that a factory reset did not work but a simple reboot did.
By dzoole
Can you add opaque box for subtitlws when we warch from smart share, external hdd etc... so practicly in thw subtitle menu choose for opaque box and transparency. Thanks in advance
- 1,365 views
- 47 answers
- 106,415 views
- 0 replies
- 2,132 views
- 2,797 views
Magic
I own an OLED 55E6V, firmware 5.30.10
I have some mkv with subtitles tracks in vobsub format. The internal video player doesn't recognize them (the subtitle button is grayed).
I have some other mkv, but with subtitle in subrip form, and they works without any issue.
I checked the mkv with vobsub subtitles, playing them with a PC and they works. so the issue is with the webOs. the mkv are streamed with a QNAP NAS.
someone of you have the same issue? in case, there're chances to have a fix?
Edit:
the same video, streamed to a Samsung Smart TV works as expected, ad the subtitles are visible and usable.
