    • By David Daul
    • By mortel
      Hello
      Modele : TV LG OLED65C15LA
      Firmware : 03.41.00
      WebOS : 6.4.0-21
      i'm french , i can't deactivate function "TV Rating Lock" , access by General > System > Safety
      (i change language form french to english before photo)
      i see on video it  possible
    • By Tom S.
      New user to the forum!
      My TV is an LG OLED 65B6P, which was working fine until a few days ago, when the magic remote pointer and OK button stopped working (was getting message that Bluetooth needed to be initialized).  After making the mistake of calling product support, they had me do a factory reset, but that didn't fix the issue, and only made it worse, as now I can't proceed from the "Start Up" menu as I can't click the OK button.  I'm dead in the water, and have even tried this with 2 different magic remotes!  I've tried the pairing and unpairing suggested on numerous support sites, and can't get anywhere with this.  Can't even find an LG service center in the Boston area.
      Any help is appreciated!
    • By Francisco Estrada
      I have the LG WP401 webOS Box model, to configure it, the previous administrator gave it a password and it did not leave it for me.
      How can I give it a factory reset or change the current password to be able to enter via the Web, to use the content manager and control manager
      Thanks for the help
    • By Costin Angelescu
      Good afternoon,
      I have a 49UB850V-ZD smart TV and has the issues below. Can't understand if its a software issue or components issues:
      1. Can't reset using meniu. I can access the meniu, I inserted pin 0000 and if I try to click Confirm it just flashes the button with no success. If I click Cancel then the meniu closes
      2. The Live TV channels are not working. There is no issue with the provider. It just not plays any channel
      3. If I connect the usb or hard-disk driver to play some movies I can navigate thru folder but I can t play any
      4. When I connect to Netflix or youtube I can navigate but if i try to play it does not load.
      5. The remote TV does not work anymore -> Only the Power Off/On button
      6. I have a magic remote TV for LG and works to navigate with the indicator
      7. The button of the TV (under the TV led) works only to open the TV -> the menu does not work anymore
      8. In the advanced menu, the Channel settings is not active among other options that are disabled.
      9. When I try to access the LG STORE it says: loading unsuccessful (82) because the hour of the TV is not the correct one. I tryed to change time to something different and also changed location and removed the location. This change did not had any effect
      What do you think? What do I need to do?
