  • 1
WiFi connection
My TV is connected through the WiFi only, however everytime when I turn it on I'm getting annoying screen "No signal detected..".
How to disable it?
8 answers to this question
Once I power TV on, I wish to get into certain application and not to see default background photo (with "no signal" notification).
It looks like I'm asking something weird...
Nobody ever faced it ?
    • By akhil7j
    • By Tunari
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
    • Guest
      By Guest
      Things that I've tried:
    • By Trung Hiếu Trần
      Specs: LG OLED 55C3
      Router speed: 250mbps
      System: webOS 2.3
      Any ideas on how to fix it?
