Hello ppl I have 55 lb 6500 i am facing issues with my magic remote as the power on/off button is not working rest all buttons are working well even battery indicator also working on power on/off button just not able to switch on or off tv with magic  remote nor am I able to connect tv with webos magic remote app  my mobile  can connect with Wi-Fi from my mobile but not scan and discover the lg tv on my lg mobile app.
You can try to reset the magic remote, instructions as per LG:
1. Press the home and back button on the remote simultaneously for 5 seconds. 2. You will see the red light blinks thrice on the remote which means the remote has been “reset”. 3. Now point the remote towards the television and press the scroll wheel that doubles up as the “okay” button. 4. You get the message that the registration is complete. 5. You are now ready to use the magic remote to control your television features. 6. If the problem persists please call the local service center of the LG dealer for assistance.
