webos 3.5 set-top-box
By Khelben Arunsun
By Prakash Sahoo
Hi Team,
Prakash Sahoo
By tarakdave
By AtWitsEnd696
janisad
Hi!
I bought an LG 32LJ610V TV with Webos 3.5.
I have SAT TV with set-top-box. I connected it with HDMI cable.
I can watch TV, but I can't find the channels, and in the program guide there aren't any channels. It says i must find channels.
4 answers to this question
