WebOS problem
By Venkata
Hello Team,
By Roy Brown
By Khelben Arunsun
By PVD
By magicschooldropout9
Mohammad Salem
Dear Sir,
I have TV LG model 43UH670 and facing a problem when using the website such as YouTube.. etc. when I am watching series or movies the app. is closing and massage appear as following:
" this app. shall restart to free the memory"
I need to resolve this issue ASAP. it is annoying me and my family.
Note that I made a rest for the TV as a preliminary solution before sending you this massage and still facing the same problem. kindly help and thanks in advance.
Mohammad Salem
