  • 1
Flush player installation
4 answers to this question
13 hours ago, diganta chetia said:
flush player to smart TV to see hotstar prime
I am going to guess you meant Flash Player, and if that is the case unfortunately it is not an installable item under webOS.  You will need to badger Hotstar and/or LG until they produce an application for the webOS platform.
Sadly any application that is reliant on Flash Player is doomed to failure due to the regularity that Adobe update it and screw things up.
    • By Jack1151
    • By wallyricks
    • By MNHL
    • By Mogens
      Kind regards
      Mogens
    • By Prashant Chavan
      Please add Jio TV app in upcoming software update.
