Subtitles option is Disabled
By garamja
By ato53
I have a new C4 TV.
Thanks for the follow-up
By MURAD
By StefanosBand
By dzoole
Silly question by me, but it seems that I can't find subtitle button on LG ThinQ app on my mobile phone? Anyone knows if we can select subtitles through the LG ThinQ app?
Dor Nissan
I have a problem enabling my subtitles on my LG UH65 TV.
All my computers are connected to the same network and are in the same HomeGroup (windows 10 feature), my LG-TV is connected to the same network.
My primary computer is working as a media server without any applications (like Plex etc..).
I have been working on it for days and now I got to the point where I can view the videos which located on my primary computer, on the TV.
At this point I wanted to watch the videos with subs so I did the following actions:
1. Pressing on Photos and Movies.
2. Choosing the videos folder, navigated to "All Videos"
3. The video has started
4. Pressed on the "3 points" button and saw there is a button called subtitles but it was grayed out and disabled.
What can I do in order to make it work?
Few things that I think you need to know:
- the subs has the same name
- the files (movie and subs) located at the same directory
- for some reason, I have to put the videos (and the music and the photos) on my library on Windows Media PLayer to be able to see them on "All Videos" directory
Thank you very much !!
