How to install apps in my lg webos tv.
        Ok, I would l like to know how to install apps in my lg webos tv, I know that the funcionally is different from android but Im sure that there is a way to do that. Specifically, I need to install goggle apps and if I can I would like to add memory space or data space to my tv.....also I would like to know if I need to buy secury services from companys like norton, kaspersky or any of those....any possitive comment I would appreciate it, thanks....👍
You should change title to something about an android emulator or workarounds to install android ".apk" apps or maybe google "converting .apk to .epk". Also there are some non-english sites that have a lot of info (had to use google translate) and one highly active russian site even has a section for questions in english.
Sent from my SM-G935V using Tapatalk
    • By anna groove
