By
atcronin
Shkëlqim Zilbeari
Hi everyone,
I have LG 55770V and after the last update the quality of SD channels have gone down....now i can watch only HD channels.
Does anyone have the same issue??? Is there any setting that can fix this?
I come from Macedonia and actually we have only few HD channels.
