Can’t find AV Inputs on Smart TV 65LM6200
So I checked the back of my smart tv, and I can’t see/find the AV input locations and apparently it says there is one on the text shown, but I can’t find any. All I see under AV is a green and a yellow input, that looks nothing like the normal av input hole. Help.
Also, I can’t find the component input too.
7 answers to this question
You shold get, with the TV, extension cables for AV an component inputs. For example, you plug cable in yellow connector, and get AV cinch connectors on the other side. Something like this:
Can you be a little more specific. As in where should I put the adapter cords in. And I’m talking about that specific tv model I mentioned. Can you maybe make some pictures or explain  so i can understand correctly.
    • By Will M
    • By Lesbo
    • By Rex G
    • By Mogens
      Kind regards
      Mogens
    • By Annie Yazbeck
      I can't find the Spotify app on the LG Content Store. When I search it, there is no result. Anyone can help me to get Spotify on LG Smart TV? I tried to use DRmare Software to download Spotify songs to USB flash drive and play them on my LG Smart TV offline for free. But I prefer to use it via the Spotify app directly.
