By OliverRC
By hollean
By Kane Murphy
By starwoodtech
By jikhead
I'm not getting any audio from the apps via the HDMI via ARC connection to my receiver. This occurred two weeks ago and was unable to resolve it, but ironically there was new firmware released that same day for my B6 (3/31/17) and this fixed the issue. However, now I again can't get it working after a TV reset and tinkering with the audio settings again. I tried to load the firmware again, but it appears this is not possible to forceable load the same firmware.
- 5 answers
- 541 views
- 5 replies
- 3,293 views
- 869 views
- 2 replies
- 3,721 views
V vp
Hi I Tried to switch my HDMI port from 1 to 3 in my smart tv. The existing port 1 was for Dish connection, when I changed the port I am not getting the sound. Then I switched to the old port 1 then I got the sound. Is there any thing I need to do when i switch HDMI ports. I tagged the port to dish and magic remote is paired with that port 1.
