I have several lg tv’s of the non smart type. Setting the recording time from the TV guide is simple. However on Webos it is extremely complex.
Let me explain.
Where I live, programs always finish beyond their scheduled time. On the non smart tv it is easy to add an extra fifteen minutes to the time while defining it. On webos you need to first define it and then go to a different application in order to edit it! It makes recording from the schedule just too complex for most users.
Please,please fix this in an update.
  • 3 years later...
Ok so I also have the same issue. It makes scheduled recordings almost useless. How incredibly frustrating to miss the last 2 mins of all my shows. Usually the most important part.
I fortunately found you can go in and edit the end time. But it would be sooo much easier if you could just set a single setting to extend all recordings. This seems an essential setting for any recording scheduler. It’s almost like the Webos creators haven’t used this feature!
    • By Peter_T
    • By wallyricks
    • By Hoghton Jim
      Many thanks.
    • By JasonB
    • By Gene680
      It turns my channel off at random times exactly 11 minutes after the hour. I checked and double checked the settings looking for timers, etc. any fixes that I’m missing?  It’s when I’m streaming on Sling.
