16 hours ago, Zipperhead said:
I did find a solution but you must be comfortable with rooting your tv. I had to root and add a startup script that would disable the internal screensaver when your app is running.
the above link shows how to root your tv.
Hi, I followed the link to your Discord channel, but the comments say that 'Root My TV' doesn't work. Perhaps I've missed something.
There is a new procedure listed.  Take a look at the FAQs
Not FAQs, the pins
Thanks for your advices.
Testing with only one device connected does not resolve the issue.
The discord link to root is unclear. I haven't looked into this solution further.
The screen saver is only set up with certain films launched via Kodi... weird
Even if the eco and power-saving modes are turned off, the screen saver might activate based on other settings or inputs not being detected. you should first check your TV's screen saver settings to ensure it isn't set to activate too quickly. These settings are usually found in the "General" or "Picture" section of your menu. Also, verify that your TV is recognizing input signals properly; sometimes, if the TV doesn't sense an active input, it might default to a screen saver.
