- 1 answer
- 317 views
By Wondering,
- smartshare
- usb
- (and 1 more)
- 1 answer
- 942 views
- 1 reply
- 3,005 views
- 1 answer
- 9,168 views
Martlea
Wonder if anyone might be able to suggest a suitable USB Hard Disk Drive for my
I did ask LG support about why these TV's cannot record properly to USB Flash Drives and they just said it doesn't work - not what they advertise is it?
They informed me the recording will work with USB Hard Drive but did not suggest any suitable models which given the TV's seot em to be using USB 2.0 and all available USB HDD now are at least USB 3.0 I would appreciate informed suggestions as to compatible models. The two I suggested to LG support were these which they state are not compatible.
- Seagate Expansion 1 TB USB 3.0 Portable 2.5 inch
So which models are compatible and why are LG using slow, years out of date, USB 2.0 in 2017anyway?
3 answers to this question
