LG Smart TV and HBOGO or NO GO??
By Will M
By Lesbo
By Rex G
goliver4
I recently purchased an LG Smart TV and all set with my subscription channels except HBOGO. I have installed the app, went through all the login setup steps including carrier and when I go to play anything I receive the message I need to download Flash Player.
I then click the link and receive
Flash Plug-in installation is not supported on this device.
I have since been doing some research to see how I can get this flippin file and with everything I am reading it is appearing that LG simply does not support Adobe files in any way and there is no way for HBOGO to play?
Feedback? G
